WMS difference overlay
Is it possible to show the difference overlay of the rainfall layer (surface last value) by using the WMS url? For now I only succeeded in showing the current map, or if I activated the measure, to show the planned map. Also if I activate the difference map, it is not visible in QGIS (which is linked with the WMS url).
Thank you in advance,
Best regards, Anne
Hi Anne,
currently it is not possible to access the difference images via the WMS connection. However, it is possible to download the difference overlay as a png.
To do this, while you're in the editor, go to Tools->API Overview. A web browser will open with the API endpoints of the running session.
Go to Overlay Services, select the intended Overlay, and then select the endpoint "Image: Query for Difference between: CURRENT & MAQUETTE"
Will this work for you?
Kind regards!
