Inlet not working
in Water
I was wondering why my inlet does not produce any water.
The actual water level is 16,39 so that should not be a problem.
936 x 792 - 76K
The inlet does produce water when I remove the lower threshold, but it seems necessary for the simulation to be accurate
Inlet not working
https://community.tygron.com/forum/discussion/480/inlet-not-workingHi @Niels Bolt ,
We will have a look and get back to you.
Regards, Vincent
Hi @Niels Bolt ,
To check/ debug your results, you can review the following:
- Object datum output (waterlevel at location inlet)
- Object flow output (shows amount of water flowing though inlet)
- Is 16,9 the actuel water level (surfacelastdatum) or configurated water level for the water area (water_level attribuut van water level area)?
I hope this helps.
Best, Vincent
