Not possible to raise land
This discussion was created from comments split from: Question regarding Measurement Tool.
  • edited April 2021
    Hello Godelief
    Thank you for the answer! It helped me out. I have a follow up question, not related to this topic.
    Within my Tygron project I am also trying to use the action 'raise land' on a certain part in my map. However when I try to select the area I want to raise, it does not allow me to do so. I checked if the layer was within the property of my stakeholder (it was) but it still won't allow me to raise the land in the area. I added in a picture below showcasing my problem.
    What can I do to solve this problem?
    Lorenzo Djokarijo
  • edited April 2021
    Hi @Lorenzo,
    If I am correct you are currently using the sculpting option. If you want to raise the land to your own wishes, I advise you to use the Levee types. More info about the levee types can be found in this link: https://support.tygron.com/wiki/Levee_type Herby you can make a new raise or lower function and add this as a measure to your desired stakeholder.
    Keep in mind that there is a difference between relative and absolute raising or lowering of the surface (more info about this can be found in this forum post: https://community.tygron.com/forum/discussion/405/implementing-measures-and-lowering-groynes#latest)
    Good luck!
    Reijn
