Is it possible to overwrite one measure with another?
After working with Tygron for some time now. I find it frustrating that is have to make sure that new measure don't overlap. Not even a cm. Because once they do, I cannot execute a whole action.
Does anyone have a workaround for this?
Hi Andy,
I can advise two things about this.
First of all, if you export your measures as a WFS file you can import them in a GIS program like Qgis and check if- and where they overlap. This can make it clear more quickly where you would need to adjust a measure if needed than just checking it in the Tygron Platform.
Second of all, it is possible to demolish and place somthing new as a measure when you make use of a time line project instead of a planning project. More information about these simulation types can be found here on our wiki: https://support.tygron.com/wiki/Simulation_Type
In a timeline project the new measure is actually build during a session or a test run so therefore it can be altered later on.
If you want to experiment with these simulation types, please make sure you save a version first so it is always possible to 'undo' your action.
Hopefully this can help you.
