Changing the size of text
Hey Tygron,
How do I change the size of the text in the indicators?
Thanks,
Sander
gem Den Haag
  • edited March 2019
    Hi Sander,
    This can be done within the Excel of your Excel indicator. This is CSS styling.
    Example:
    style= “font-size:14px;”
    When you are working with a default indicator you can find this styling in the green cells on the maquette tab.
  • What about the size of text of the descriptive text/graph on the side?
    Last time when Godelief and I sat together she made all the text bigger in the indacator, not just the text of the excel output.
    She said that if I asked the question here she would put out a little guide to do this.
    The reason someone would want this if you gave a presentation on a bigger screen. The text would be more readable!
    Sander
    gem Den Haag
  • Hi Sander,
    The description text in the indicator panel has default styling and cannot be changed.
    However, you can copy this text and put it in the Excel file of the indicator and add styling to it.
    The explanation of the indicator will then be visible above or below your table. See also the attached images and the steps below for an example with the green indicator:
    • add the indicator text for example in cell C10 on the Maquette tab with the new styling tags
    • add in cell B10 in the concatenate function C10 to the formula
    • save and update the indicator Excel file
    • leave the description box of the indicator empty and optional hide the score graph
    • the result indicator panel now has the description text above the table
    1914 x 468 - 121K
    1897 x 466 - 110K
    740 x 511 - 62K
