error import GeoJSON
Error:
Invalid:um:ogc:def:crs:OGC:1.3:CRS84 Coordinates: Latitude 393 44.4'N is too close to a pole.
When I try to import my GeoJson I get the error discribed above.
In my project I did load the same area (coordinates) as the file I want to import.
Does this error mean that the file that I want to import goes over the borders of my project?
Hi Emmen1,
The error message basically means that the data in the WGS84 coordinate reference system can't be imported correctly. Can you try to transorm the data to another coordinate system in a GIS, for example the Amersfoort RD New/EPSG 28992 system and then import the data again? I think this will solve the issue.
