WMS query parameters
I think the Tygron WMS structure both directly from the project and from geoshare support multiple query parameter. I however can't get the exact syntax right I believe therefore stuff keeps on going back to default.
The main goal for now is to change the styles default from INTERPOLATED to NEAREST (Grid Overlay - Tygron Preview Support Wiki). I want my WMS output to look exactly as the actual raster not some smoother interpretation of the actual input. Nearest should be the one for this. In addition I'm curious if I can use Geoshare for a COLOR raster when I'd use a 3 band RGB geotiff as input with the layer=color option. Is this supported?
Other options I'd like but are currently not the must have are the transparency. I believe something like &styles=nearest& and &transparency=false& should be somewhere in the URL.
So something like:
geo.tygron.com/share/...../wms.viewer?styles=nearest&transparency=false&token=**
or
geo.tygron.com/share/...../wms.viewer?token=**&styles=nearest&transparency=false&
or
power.tygron.com/web/wms?REQUEST=GetCapabilities&styles=nearest&transparency=false&token=****
I however can't get this to work. I think I once managed it in QGIS but can't seem to reproduce this at all.
So how can I configure my WMS to use these options?
