Scaling beyond your system's capabilities
The Tygron Client application is a powerful tool to see and manipulate your project's data, in large part because of the 3D visualization. But as you scale up your projects, you may at some have so much data that even the more capable hardware is pushed to its limits. In these cases it's good to know there are multiple ways to go beyond!
If the graphical rendering is the bottlenect, you can change the graphics settings from the main menu before entering your session. Find the setting in the top right, and change it as deemed appropriate.
If the memory of your system is a limit, you are likely (knowingly or unknowingly) dealing with extremely large datasets. Consider using the API, and workflow automation tools such as FME, and WFS and WMS viewers, to leverage their capabilities for filtering and further processing of data.
Finally, remember that the Tygron Platform also offers both a 2D and 3D web viewer, optimized specifically to have insight into Project world without the need to keep in memory every bit of data its composed off. This can be a very solid solution for both your own need to visualize the data, as well as for sharing the visualized projects and its results with your end users!
