How to manually change the terrain
edited April 2023 in General
I would like to change the surface and/or underground type for some soil layers in my project area. For instance from sand to clay. What is the easiest way to do this (besides manually changing the attributes of a layer)?
  • edited April 2023
    Hello @Jappe de Best ,
    In case you have the data you want to implement available as a Geo data set (GeoJSON, Feature Service, Catalog Service, etc) you can use the Geo Data wizard to overwrite the default surface and underground types with your own data.
    In your case, go to Current Situation > Terrain > Import Geo Data
    See also:
    https://support.tygron.com/wiki/GeoDataWizard
    Vincent
