Import KNMI data automatically
Is it possible to import the KNMI excel with the weather data directly in the heat stress configuration wizard?
  • Hi,
    directly loading the KNMI data is possible by automating it yourself using the API (REST API - Tygron Support wiki), but not through the wizard.
    also note that if you often use the same weather data for calculations you can save the settings in a template and use this for future projects.
