API with FME
Hi Support,
I got ambitious and would like to use the API with FME. Do you have an example for me?
Thank you,
Ward
  • I should perhaps be a bit more precise with my question.
    Let say I'd like to make a POST request to get the domain sessions.
    https://engine.tygron.com/api/event/io/get_domain_sessions/
    Would it be possible to provide me with an example of how to do this with FME? I did read the wiki (https://support.tygron.com/wiki/REST_API)
    A print screen of how far I got (not with my actual b64 user:pw)
  • Yes, figured it out.
    My mistake. I should have read your wiki better!
  • Hey Ward,
    I'm of course very happy to hear you were able to resolve your question on your own. I am curious, however, what it was that you changed or resolved to make your call work. Would you be willing to provide a bit more info?
    Kind regards!
  • Yes, well, I worked with R first and using the API is quite easy. That's why I expected it to be even easier with FME. But it turned out that you have to read the wiki and read everything. 😊
    The next sentence in your wiki is quite important and easy to miss.
    Note that the supplied Content-Type header must be "application/json", the Accept header must be "application/json", and the f=JSON parameters must be added to the url. Also note that when sending parameters in JSON format, optional parameters may be left out entirely.
