Documentation underground evaporation
Hello forum users,
I was looking into the evaporation, and the theory behind it. I ran into something regarding the documentation of the evaporation from the unsaturated zone. On the Tygron Wiki, the equations used are documented*. However, I was wondering, should the 2 equations circled in red not we swapped the other way around in the documentation?
d_gw,t is the depth of the groundwater level. If the ground water level is situated below surface level, d_gw,t is a positive value. So I think water could evaporate from the unsaturated zone. So, the second equation should be followed instead of being just 0.0 right?
* https://support.tygron.com/wiki/Underground_evaporation_formula_(Water_Overlay)
Hi @thies ,
Thanks for your remark regarding the documentation. We will let you know when we have looked into it.
Hello @Godelief ,
Thanks for your reply!
Just to be clrear, I think that the implementation of it in Tygron is correct, or at least, the evaporation I observe is as I expact it to be.
My comment is only regarding the way it is is documented.
Thies
Hi @thies,
We have looked into it and updated the Wiki accordingly. There was an error in the documentation of the formula, the greater than (or equal to) should be less than (or equal to). Thank you for notifying us!
Hi @Godelief,
Great to hear from you. Happy that I can contribute.
