Tip: Help! Constructions are not redrawn when ending a test run!
Sometimes it can happen that a project is not fully brought back to default when ending a test run. Not all constructions are redrawn as they were in their original state. These constructions were affected during the test run by implementing an action or measure on them.
The most common cause for this to happen is that in the source data (OSM, BGT, BAG, etc) some polygons are slightly overlapping adjacent polygons. This overlapping is usually unnoticable in the main view.
A quick solution is to individually delete constructions with this problem in the editor and replace them manually with the same construction. The platform will ensure that no polygons are overlapping while manually replacing these constructions.
