placing solar panels in Tygron based on there location in geodata
I have a question regarding the use of solar panels in Tygron:
Is it possible to place solar panels on rooftops in Tygron, based on a geodata file (geojson/wfs) with this locations?
  • Accepted Answer
    Hi @Hans van den Bosch ,
    It is possible to import a file/use data from a service with buildings that have solar panels on the roofs. In this file the polygons (buildings) should have the attribute SOLAR_PANELS = 1. In the Geo Data Wizard you can import this as Buildings. in step 4 choose for Update existing buildings. The buildings in the Current situation are then updated with solar panels on the roofs.
    You can also use the file/data from a service for a measure, but then you cannot update the existing buildings. With the measure option you demolish the current buildings and construct new buildings with the solar panels.
    See also the demo https://support.tygron.com/wiki/Demo_Wind_Solar_power_project project for possibilities regarding solar panels.
