working together on a project
Hi, I was wondering how you can work together on a project? We work with several students on one project. Can we all login to work on the same project?
Thanks in advance for the answer!
Karin
  • Hi Karin,
    Thank you for your post! Yes you can work together in one project. One person has to start the project via edit project and all others can join via the join option in the main menu. You need to make sure that the amount of persons who want to join correspond to the amount of stakeholders in the project beacuse you will get a stakeholder role when you join the project. Important to knwo is that everybody has the same rights so it does not matter which stakeholder you represent. It does influence the 3D world options you see in the future design tab.
    Also, I strongly advice to work with version control https://support.tygron.com/wiki/Version_Control. And to maken sure student make clear and strict agreements on who does what task.
    In this video even more tips and tricks are shared. It depends on what it is you want to achieve with the students what is the best way to work together in a project. Maybe this can help you even more. https://youtu.be/4s0voa6Uv2g
    If needed please add more info to this post so I can give more tips and info on how to work together in a project.
