Water balace
Is it possible to acces the Water balance in the API? And if yes, what would be the URL. I am especially interested in the Sewer Out External.
Hi @Ward van Laatum ,
Yes it is possible to access the water balance via the API on the Preview.
Go to the Tools tab > then click on API overview > Content items and then at the bottom click on Water values.
Here you will see the contents of the water balance panel listed.
Hey @Godelief,
Thank you, found it. But as usual I have a follow-up question. I'd like to have SEWEROUTEXTERNAL for a specific area. Is this possible? Or how would I calculate it?
I used the default value for the SEWERPUMPSPEED (0). And I kind of assumed there was no water leaving the sewer at all.
Not sure if I understand your question correctly, but you can also find the Sewer Out External also in the water balance panel, so you don't have to calculate it. Is this an answer to your question?
Hey hey,
Hmmm no. Sorry, let me explain it better. I start with an area, the area of interest, and i'd like to make a water balance specificly for that area.
If I understand correctly, the waterbalance in Tygron, it is about the In's and Out's for the entire map or project. And I am only instersted in a specific area.
So, in the picture below, I'd like to have the sewer_out_external for the area in green.
I hope this makes more sense.
Hi Ward,
The water balance is linked to the calculation area of the Water Overlay (see step 1 op the Water Overlay Wizard).
There are basically two options:
