Water on buildings?
When using Rainfall Stress in areas outside the Netherlands, water is projected on top of the buildings, this is rather confusing.
is this correct? Or do have to change something in the settings?
Hi Andy,
Please see this topic with a similar question: https://community.tygron.com/forum/discussion/comment/87
Does this explain and answers your question?
Hi Godelief,
the problem still occurs:
Hi Andy,
Ok, can I then take a look into your project to see your configurations?
What is the name of your project and can you give Support acces to it?
Hi Andy,
Some more information about the water on the roofs:
Depending on the grid size, if there is water next to a building in a grid cell and the building is on part of the grid cell, the water in this grid cell will be displayed also on the sides or on the top of the building. The larger the grid cell size, the larger the overlap can be. This is only visually.
You can try to use a smaller grid size, in combination with for example a limit area to reduce calculation times.
