Merging time sequence steps
A common data we get concerning Water Module calculations over longer periods of time is whether we can incorperate a proper time sequence for the entire calculation. For example, 2 months worth of rainfall data, with precipitation numbers per day. Since at this time only 50 discrete datapoints for such a time sequence are processed, you can't simply state an exact value for each of the 60 days in the desired calculation.
However, remeber that the steps in a time sequence do not need to be uniform. If there is a period of multiple days during which no significant rain was measured, you can combine those into a single time step. Turning something like this:
Into this:
This may help you to squeeze in those few vital extra datapoints.
