Import zoning plan with categories
when I import a zoning plan using "import geodata", the zones are set as without categories by default. Is there a way to import zones with categories using a geojson?
If don't, where is the documentation about excels for zoning?
Thank you.
  • Hello Josep,
    When you import a zoning plan via "import data" you can only import a zoning plan withour categories.
    You can import a zoning plan with categories. this can be done in the Zoning option, select Add zoen with categorie. Select draw area and pick the Blueprint drawing tool. And select the Plan wizard option.
    The only thing is, if you have mulitple zones and teh permitted categories vary per zone you need to repeat this process per zone. it is possible to select multiple categories in a zone but not multiple zones witrh multiple categories.
    I hope this helps you.
    About the documentation, this is all we have: https://support.tygron.com/wiki/Zoning#Excel
    If you still have questions, please let us know!
