Set panel size
Hi Support,
The panels have a default size it seems. Is it possible to change there size so I can fit some more information in?
Thank you,
Ward
Hi Ward,
Yes it is possible to change the size of panels. When you select a panel in the left menu, you can change the properties (width and height) in the right menu. With the panel layout attribute you can move the panel so it will pop up in another place on the screen.
The size of the indicator panels however are fixed. To create more space in the indicator panel, you can uncheck the Graph checkbox and leave the description box empty (see this Wiki link for more information: https://support.tygron.com/wiki/Indicators#Graph )
Thank you! That was an easy question :)
Sorry, I was to focussed on trying to change it with Java in the panel itself that I forgot the check the settings in Tygron.
Thank you for the fast answer.
No problem of course Ward, I'm glad I could help you.
