Viscosity
Not quite sure, but I don't think it is possible to change the viscosity of the fluid. In most cases I model water and therefor it is sufficient. However, I might have a assignment where I would like to model a mud flow due to a dam failure. Could it be possible to change the viscosity of the fluid in the calculations?
Hi Ward,
It is not possible to change viscosity in the water module. You could look if there are some parameters you can change the flow of the water approximately compared to mud. Values like infiltration and evaporation can maybe help you with that but I connot say anything about the accuratecy the model will have. And I'm not sure if there are enough attibutes you can change to create a propper estimation of a mud flow.
