Missing category Senior houses
In my project Bossche omgevingsgame i miss the category 'senioren woningen' in de action menu. When I want to select the actions for senior housing, the category isn't there to open.
How can I slove this problem?
Lee
Hi Lee,
Thank you for your question! I have checkt it and came to the conclusion the Senior housing does indeed miss from the list in the right panel.
I did find a work around so I can help you get the senior houses afterall.
It is liked to the Region, you can select the region on the bottom right in the right panel.
-Set the region to Northwestern Europe
-To trigger the list to refresh you need to select another action menu in the left panel and than switch back to the action menu you want to add the senior houses to.
-In the list the option for senior houses is available now.
-Add the houses to your action menu.
I hope this works for you, Lee.
I will report this bug so this can be fixed in one of the upcomming releases.
Hi Hansje,
Thanks a lot, it worked!
Lee
Hello Lee,
Just a quick update, the fix is released in the big LTS update from last week.
The category is present in the list now without the need of a work around.
