Calculation demolition costs
I see a difference in the calculation of the demolition costs. The demolition costs are in €20 m2 (square meters), so I expect 100 m2 is demolition costs of €2000.
Could you explain the difference in de atachments.
501 x 164 - 108K
508 x 268 - 173K
Hey Lee,
It could be that the difference is caused by the buyout cost of a construction. Please check the function values for the buy out cost of all constructions and the spatials for the buy out cost of spatial constructions.
I think this will explain the difference in costs.
Hi Hansje,
The buyout costs are €0,- I've already checked that.
Lee
Hello Lee,
May I ask if you try to demolish this as an action or as part of a measure?
What can help to find out where the costs are comming form is to add an budget indicator and preform your demolish action. After this is finished you can click on the budget indicator and open the balance. Now you can see in more detail where the costs are made for. If it is not clear, please post a screenshot of the finacial balance so we can help you specify how the total costs are established.
Hi Hansje,
That answers a part of my question, because the discussion in Den Bosch started with the demolition of this building (see picture 01). I still can't explain why the demolition costs are so high (see picture 02).
Hey Lee,
to get a bit more insight into what the costs break down to, can you open up the "Industrie" category in the budget as well? It should show all the object that have been demolished in that category, along with their individual costs. If that doesn't further narrow it down, can you post another screenshot of how the entries look opened up?
Hi Rudolf,
See the attached file.
Lee
Hey Lee,
so according to the budget overview, all the costs are caused by a single structure. That already helps narrow down our search somewhat.
Can you please check/do the following:
Can you try these steps as well and let us know the result?
Hi Rudolf,
Thank you very much, I see what is causing this high costs. I'm going to change the values.
Lee
