Changing an indicators weight/belang
How do I change the weight of an indicator score?
Or how I remove the weight completly?
  • Hi Sander,
    You can adjust the weight of an indicator in the stakeholder settings. Indicators are set per stakeholder and can differ in weight per stakeholder, therefor this setting can be found per stakeholder in the stakeholder settings.
    You cannot completely remove the weight, but you can set the weight to f.e. 0.0001% so the importance is so low that it will (almost) not count. If you set the weight to 0.0 the indicator will be removed from the stakeholder completely.
    More information can be found here:
    http://support.tygron.com/wiki/Stakeholders#Adjusting_Indicator_Weights (how to adjust the weight)
    http://support.tygron.com/wiki/Indicator_Weights (general information about the weight settings, including example of how to set the right percentage)
    I hope this helps.
  • edited May 2019
    In addition, The http://support.tygron.com/wiki/Indicator_Weights page is completed with the information about how to set the weight to almost not countable.
